Old Jun 9, 2013 | 12:40 PM
onehundred80
Default Re: 2005 Roadster Auto Gear Shift Lagging
Originally Posted by Billerickydicky
I am taking the car into the local MB dealers on Wednesday for them to look at.
I have told them the symptoms and suggest that it may be low on ATF and would like that checked.
They have however said they would need to do a diagnostic check first (£75) and take it from there.
Can you tell if a gearbox is low on fluid by doing such a test - what can it show them about the state of the gearbox?
I would have thought the first thing to do was check the level before billing me for a diagnostic check. It might be just a low fluid problem - if not then certainly look into it further and then bill me!!
Richard
You check the level with a dip stick just like the engine. They did not come with a dipstick and the cap is locked for a one time opening which requires a new lock to be put in. The cap fits fine without the lock though.
The method to check the level is mentioned on this forum and you should do it before going to the dealer.
