Old Jun 13, 2013 | 09:53 AM
ijaved's Avatar
ijaved
Default Re: Hazard light flashing after locking the car
Originally Posted by alaxfire
Yes, the alarm does have it's own battery, but most are toast by now.
As to battery drain, you can remove the neg (-) battery cable and connect a multimeter between it and the neg battery post. You should see around 35 ma normal drain.
If you see a heap more, start plucking fuses till you locate the source circuit.
I always wanted to use multimeter thanks for the heads up I will check it up over the weekend. I am also doing search on the forum and I think I nailed the issue.
I am posting my find for someone else who might have this problem in future.
Crossfire Alarm Issue! - CrossfireForum.org <-- The Siren Module has the dreaded "Cricket on Crack" syndrome.
https://www.crossfireforum.org/forum...ying-bird.html <-- Actual alarm needs to be replaced.
Part # 5124443AB
ChryslerPartsDirect.Com
Quick Order
Old Part Number: 5124443AA (replaced by newer version AB)
New Part Number: 5124443AB
Part Name: SIREN ALARM
MSRP$185.00
Online Price$129.50 (quoted on June 13,2013)
Update:
Chrysler dealer wants $291 and they don't have it in stock either. However, the part guy gave me Mercedes part number and said I can check up with them as well. I usually find Merc parts to be $100 cheaper. Part number is A2198203226.
Got off the call with Merc and they are selling it for $202 Canadian. FYI for anyone out there.
