32krazy!
he is also banned from mbworld for shady dealings and copying other shops designs. intake setup looks amazing a lot like the needswings setup. same for the fuel rail he sells, stolen from ttm design
I presume the "
he" to which you refer, is the fab tech guy?
boostmonkey
The amount of heat the air will absorb from the aluminum Y-pipe is insignificant compared to the amount it will pick up going through the supercharger.
True
I guess I was looking at the whole intake.
An afterthought was that maybe 2-3mm of insulation (silicone?) could be continually sprayed (built up) on the internals of these after market tubes. You'd retain the bling but loose some ID, but heat is our worst enemy.
I was even wondering how you could drag some of this CAir and push it into the valley around the cooler.
