Old Jun 14, 2013 | 07:52 PM
onehundred80
Default Re: Relentless Mechanical and Electrical Failures :-)
Originally Posted by gcongle
I have done as instructed, connected the positive probe in mA. Set the meter to mA. I have tried putting the positive probe on the positive post the the negative probe on the negative post. I've tried putting the positive probe on the positive post and the negative probe on the disconnected ground. The meter is set on AC. I don't get a reading either way. Any other sequence with the probes?
Checked in the trunk, under the foam and found no water, or dampness.
When I try to lock the doors automatically they don't work, but the lights blink.
Any suggestions?
You want DC not AC.
The picture of the multimeter shows the symbol mA with a squiggle above it and three dots under the squiggle, that is what you want to select. I am a doofus when it comes to sparky stuff, but that is what my MM shows as well.
