cherriestu
Hey there,
I am new to this forum and done some searching around already but not really found solution so thought would try posting this. I recently had an issue with the "sticky key" so I followed your post on that problem and managed to resolved the problem. I have noticed thou that recently the horn doesn't appear to work but as I haven't used the car for a while previously to sorting out "the sticky key" I couldn't honestly say if that had anything to do with it!
Anyway just wondering if anyone had any ideas how I could check the horn, what I should look for etc? I have already check both fuses (main and one under bonnet) so I know its definitely not the fuses.
Also while I am here, this really isn't something I am concerned about it as its been like this for a good year but my air conditioning always is warm, even when I turn it to cold. Any suggestion on how to fix this? I am assuming it just a case of it needs re-gassing or whatever its called. Cheers
When you performed the sticky key mod, did you remove the steering wheel?
