Old Jun 16, 2013 | 08:32 PM
onehundred80
Default Re: Horn not working? Suggestions?
Originally Posted by alaxfire
Grille : Grasp it firmly about 6 inches either side of center and pull straight out.
I think this is asking for trouble, you will be pulling against the square lip on the clips and probably break a clip.
I find it best to tilt the grille forward at the top just enough to get your hand down the back and release each of the four clips by pushing it down. Yanking it straight out will ensure that you have less than four clips eventually.
This is plastic and as it ages it gets brittle, I was already down to two clips when I got the car, three if you count the one hanging on by the skin of its teeth. I intend to find a way to repair these clips or make new ones as required.
