alaxfire
I run an old Alpine in mine with the 2v pre-amp outs.
I initially tried to use the pre-amps, but even with the volume all the way up, it wasn't loud enough.
I just wired the HU's speaker wires to the amp and it works just fine, plenty of volume.
I printed out the wiring for the Alpine, and the wiring from the stock radio.
Taped the 2 sheets together and connected the dots, easy peasy Japanesey.
TASTY flashlight ?
"Tasty Flashlight" = frees up two hands..
Realize your volume is not going to increase as you are still running through the same amp. "Unless" you already have an aftermarket installed with 2v outputs being used.
Joys of a used car.. replacing the wife's "new to her" Vett's HU this weekend and get to figure out what the previous owner has done when the original was replaced.
Um.. where are you located? There are a few members around that don't mind helping with hands on..
