Old Jun 20, 2013 | 02:45 AM
syfi's Avatar
syfi
Default Re: Cheap tie rods at Tractor Supply
Please explain your common usage of the word solid, it is confusing.
So the DOM used on these tubes could be anything from low carbon to your TuffDOM, you see where I am coming from and that is my argument in the first post, it all depends on the steel.
I totally agree with you. There are over 3,500 different grades of steel, encompassing unique physical, chemical and environmental properties. The solid I was referring to was the common A36 we use on a daily basis. And I agree that it all depends on the steel. Example: I put a 1/2" solid rod of A36 into a hydraulic break and bend it quite easily. The same 1/2" DOM tube will take more pressure to bend, even with the hollow space inside. Try to bend the same 1/2" solid rod of tool steel and it will snap.
All I was stating was that the DOM is adequate and comparable to using solid steel, but no one uses solid steel because of weight, when a tube can get the same results. Even a low grade carbon when cold drawn will gain much more strength from compacting the grains. Same can be said with aluminum. I've cold drawn and annealed aluminum tube to a hardness comparable to the same wall thickness of SS tubing, all in the name of weight and cost savings.
The DOM used on the Allstar Performance tubes I used have been tested on the Modified Dirt and World Of Outlaw racers with great success. And that is some kind of abuse for suspensions.
