Rudy,
As long as these come with step by step instructions for those of us that are not mechanics or rocket scientists in our day to day lives, I am in. I'm more interested in getting some of the travel back in the shocks due to lowering, as well at the camber adjustment. Dips in the road are cringe worthy in this car.
Thanks!
Jeff
OT but did you trim the bump stops on the rear? If so then the sway links are are what is going to help you with the BANG! On bumps. If not those stops need to be cut down. As far as install goes these are all super easy, basically a bolt on each end. Adjusting is straight forward as well but you can leave that for the alignment guy after you set them to an approximate length based on the stock pieces.
