Old Jun 23, 2013 | 06:47 PM
onehundred80
Default Re: HELP!!! 05 Crossfire stuck in 1st gear...
Originally Posted by Skippy911
Alright I've had a major issue since I bought my 05 Crossfire.. 1 month after I bought my car it would stall out in 1st or 2nd gear and I would Have to stop turn the car off and restart the car for it to drive correctly. 4 months later the same problem consist but now the car is stuck in 1st gear and will not shift... Also the check engine light is on and the codes I'm getting are p0715 & another code that says the tcm has malfunctioned I think it's p0705. Also I go to put the car in reverse and it jerks into reverse and I place it in D and it jerks into 1st then I drive it and the cars RPM's rev up and doesn't shift??? I unplugged the TCM and the battery but the check engine lights still on and the car still acts up.... What gives, pleasssse HELP?!?!
Try search P0715 it gives a lot of info and solutions.
Also search your other number.
Unplugging the offending part will not clear the code, you need a code reader to do that.
