Old Jun 23, 2013 | 07:00 PM
Skippy911's Avatar
Skippy911
Default
Originally Posted by nashcrossfire
hey people's. im back.
ok so I changed the condutor plate and got the yellow plug also a new gasket and new atf and had thrm fitted.today the mechanic said that the car still the same. im so pissed right now.
he said the car knocks in to drive and still not changing gear.but he rang me yesterday and said that the bottom of my car was drenched in oil.which must of been the old gasket.
so where is the turbine speed sensor on the crossfire?
anyone got a part number please and even a picture.it can only be that right or?
Hello sir.... I'm having the same problem read? Alright I've had a major issue since I bought my 05 Crossfire.. 1 month after I bought my car it would stall out in 1st or 2nd gear and I would Have to stop turn the car off and restart the car for it to drive correctly. 4 months later the same problem consist but now the car is stuck in 1st gear and will not shift... Also the check engine light is on and the codes I'm getting are p0715 & another code that says the tcm has malfunctioned I think it's p0705. Also I go to put the car in reverse and it jerks into reverse and I place it in D and it jerks into 1st then I drive it and the cars RPM's rev up and doesn't shift??? I unplugged the TCM and the battery but the check engine lights still on and the car still acts up.... What gives, pleasssse HELP?!?!
