Old Jun 25, 2013 | 04:03 PM
tbwilliames's Avatar
tbwilliames
Default Re: Full Throttle Stall
Originally Posted by RL67037
You have a CEL - can you get the codes?
Sorry about just getting back on here. The CEL went off for a while and this morning came back on. The took a little longer to start then it normally does. I did have the code pulled and it is still the CPS code i was getting before.
The no longer dies at stops or when driving, not it is just when i push the throttle to 100%. I did a test today on the interstate (it wasn't busy). I was doing about 50 mph, once again full throttle. However this time, the car does not turn off like before. Instead, the car drops out of gear almost like it is in neutral, you can rev the engine to see the RPM's increase however there is no power to the wheels. I do put the car into neutral and then back into drive and it still does nothing.
I left it in drive once i got to about 10 mph the transition re-engaged and i was able to put power to the wheels again. This has to be some kind of safety feature of the car. Thoughts anyone?
