Old Jun 27, 2013 | 09:49 AM
West Peterson's Avatar
West Peterson
Default Re: Adding Foglamps on base model?
The install is extremely easy. Here are two threads you may want to read. I wired mine directly to the fuse box as mentioned, and the fog lights work with the switch just as the factory intended. They even come on for a minute or so after you shut off your car and leave it, just as the factory intended.
You DO NOT have to remove the dash switch.
https://www.crossfireforum.org/forum...l-06-base.html
https://www.crossfireforum.org/forum...-roadster.html
