Reichsrundfunk
Thanks for your input! I'll check to see regarding the AIR Pump however I can tell you it is not making any noise from what I can hear, of course they are really not supposed to unless they seize up. Re the RCM I'll keep that in mind but first I'm going to burn out the last of the existing gas and refill with either BP or Shell 93 octane and personally put on the fuel fill cap. I may also use my OBD-II reader to reset the computer and see what transpires.......
Stay tuned
-George-
When the air pump is working it DOES make an audible high pitched whine, this is normal. It should run for 20-30 seconds or so at engine start.
If it is not doing so, then pull the K40 ( RCM ) - module in the box by the battery, it is the one with all the fuses on top. Remove the plastic cover - (easier said than done sometimes ) Look at the relay on the end closest to the firewall, see if the contacts are badly burnt.
If so, you have 3 options :
1. try pulling the armature off the relay and filing the contacts ( this will last for a while )
2. replace the relay ( hard to find the individual relays, and hard to de-solder the old one )
3. get a new RCM / K40 - $$$$$$
-- George --
