Old Jul 8, 2013 | 05:30 PM
+fireamx's Avatar
+fireamx
Default Re: Cold Air Intakes...Snake Oil?
Originally Posted by Wes__Hutchinson
So a 30hp and 20 something torque increase with just a CAI? That is impressive. How restrictive and hot is the OE system? If I was a M-B executive I would be firing some engineers. I can personally attest to the dismal results I have seen with every CAI to date. Mostly Asian cars and diesel trucks. The scant gains didn't justify the expense in most cases. A horsepower or two and slight gains in torque is what I have personally witnessed.
I noticed you are using the supercharged engine for your test. How does the N.A. fare?
How well an aftermarket CAI works usually comes down to two things.
How restrictive the original factory equiptment is, and how well the aftermarket intake was designed to flow.
That being said, the NeedsWings CAI on an automatic equipped Crossfire will cut nearly 1/2 sec. off its 1/4 mile ET's.
I don't know what that works out to be in Net H.P. But it's a significant performance increase.
