Old Jul 10, 2013 | 12:13 AM
onehundred80
Default Re: Electric seat wont work
Originally Posted by red-in-la
You have one of two choices: 1. A wire shorting out, maybe under the seat. 2. A wire shorting out somewhere else. At least that's been my experience.
I had a Corvette that would randomly tilt the driver's seat up and move it forward. Not pleasant. Sticking my hand under the seat and wiggling the wires would sometimes make a difference. After taking the drivers seat out 5 times I finally gave up and pulled the fuse.
Get a wiring diagram and see if there is a wire common to both seats.
Best of luck
Generally I'd say a short would blow a fuse, otherwise it's a bad connection somewhere.
OP - Does the seat work with the door open and not closed or something similar?
