Electric seat won't work
Old Oct 24, 2013 | 02:10 AM
2katman2's Avatar
Default
1234567890
Old Feb 27, 2021 | 10:49 AM
Born4tech89's Avatar
Banned
Default Re: Electric seat won't work
Under the dash right below the steering wheel you will find a box make sure it's pressed in firmly. That is your seat relay, which controls your adjustments. Very cheap part if it's completely shot. Super easy to install. Literally plug and go. Hope this helps if you haven't already solved this issue
Old Feb 27, 2021 | 01:28 PM
PLease check post dates, this is from over seven years ago, and Anthony left the forum three years ago.
It IS interesting to read this thread, back then, we didn't know the seat relay was about to start showing it's failure rate big-time.
Today, it is common knowledge that the seat relay is the first thing to suspect, we didnt know that back then.
Kinda like, just in the last three or so years, the OEM AM/FM heads are starting to die like flies....
Old Feb 27, 2021 | 02:05 PM
Banned
So.....about that radio? I'd there any other fix for this besides having to fork out for a new one? What is causing these radios to out like they are?
Old Feb 27, 2021 | 02:49 PM
Speaking as an electronics tech (since 1982) and having worked for JVCKenwood in R&D, I can tell you there are several possibles. None are economically fixed, new heads are $80-200. Labor is $60 to $120 an hour these days for anyone who knows what they are doing. And finding tech manuals and parts is about impossible.
1) The watchdog timer circuit for the uP fails, probably due to a "dried out" electrolytic capacitor in the watch dog timer itself. This means the little 'tickle pulse' at power up never happens.
2) Corrosion on a circuit board, that eventually eats away a path under an LSI or VLSI chip. This corrosion can come from condensation due to years of warming up and cooling down in extreme weather conditions, causing small amounts of condensation. Reactions due to TINY current flow thru this condensation makes things worse, but it takes time for this to show up - our cars are getting old, so the time has come.
3) Corrosion on pins that connect circuit boards, meaning that one board can't "talk" to another board.
4) Any number of other issues common in elderly electronics.
5) Damage to electronic components due to surges on the 12 volt input from weak battery, crappy alternator (poor regulation, severe ripple), severe spikes due to starter engagment or disengagement in the presence of weak battery or corroded battery cable clamps, bad/missing ground strap from chassis to block, etc. (This is why I did the mod James talked about, and I did it even to my Ranger.)
For $85, you can find way better heads than our outdated ones from the 1990s.
smokey847
Jul 21, 2015 11:34 PM
awdspyder98
Jan 2, 2014 10:24 PM
32krazy!
Aug 25, 2010 06:24 AM
xfire1
Mar 18, 2006 04:27 PM
WestOzCrossFire
May 31, 2004 10:32 PM
