pizzaguy
This is a super-simple but time consuming fix. You should have no problems and be done in an hour or so.
Unlesss........................................... ....... The thing freezes up and you have to drill the pin out. NO ONE has fun with this and EVERYONE curses, screams, sweats and suffers at this point.
I was lucky, mine froze up at a gas pump. It was a $100 tow home and, later in the week, when I went to take it apart, it had freed up! Did I ignore it and go on?
NO!
I took it apart and fixed it anyway. Like I said, I was lucky and it was EASY 'cause it was free to move, I just pushed the pin in as I yanked the assembly out!
Sorry it got you - this is a warning FEW will listen to: If yours is not stuck, FIX IT TODAY and DO NOT WAIT for the hell that awaits you!
Thanks. But when u say u pushed the pin ? how? finger a screw driver and if that doesnt work how do i drill it out ?
I seen pics with a hole made. but how do they or what do they use to make this hole.the link below shows how its suppose to look like after the pin is remove.
How to remove the ignition if you can't turn the key - Benzworld.org - Mercedes-Benz Discussion Forum
