Old Jul 10, 2013 | 07:35 PM
onehundred80
Default Re: P0410 - How to fix it for those who have fixed it already
Originally Posted by turbomar
First solder as per the thread instructions. If code p0410 persists however, you most likely have burned contacts of the air injection blower relay, 1 of the 5 relays in the RCM. At that point, Your best bet is to buy a good used or a new RCM
If the relay is burnt and you are good with a soldering iron you can replace the relay for about $2. The RCM will cost a lot more.
https://www.crossfireforum.org/forum...tml#post550548
