Old Jul 11, 2013 | 02:22 PM
MXQB7's Avatar
MXQB7
Default Re: Ignition switch problem "pin"
Ok you guys thanks for all the Help! But now i have another problem !
The car wont start!
I was finally able to take of the pin , well more like grinding it with a dremel tool until it was even then took it off.
I follow the instruction and i got the ignition switch to Switch! lol
I put it all back to order
before i put all the screws back on i tried turning out the car.
And now it doesn't turn on all!
they ignition switch is fix but its not even cranking the engine at all .
all the lights on the dash board come on and the alarm works
But the car doesn't make a sound when i try to turn it on!
and yes i put all the cables back together , triple checked it
plus if i was missing one the switch wouldnt work right?
i was searching and i found out that it might be this : attached -------------> How to Repair Relay Control Module (RCM) - (Mystery no Start)
but does this cause after fixing the ignition switch
is it a common issue
or was it my luck that it happen at the same time
PLEASE HELP!
