Old Jul 11, 2013 | 02:39 PM
onehundred80
Default Re: Car Won't Start After Fixing "Sticky Ignition Switch" ! HELP!!!!
Originally Posted by MXQB7
My Car wont start!
its not even cranking the engine at all .
all the lights on the dash board come on and the alarm works
But the car doesn't make a sound when i try to turn it on!
i was searching and i found out that it might be this : attached -------------> How to Repair Relay Control Module (RCM) - (Mystery no Start)
but does this cause after fixing the ignition switch
is it a common issue
or was it my luck that it happen at the same time
PLEASE HELP!
There is the plug that is on the back of the ignition switch, did you put that back on, did it get damaged on some pins?
Also, there is the halo ring that goes around the ignition keyhole, is that on? The other end of the halo wire plugs into the SKREEM module if that has become damaged or unplugged the car will not start.
Someone forgot to put the halo back on a few years back, but I think it cranked but did not start.
