Thread: Battery Light
Old Jul 30, 2013 | 07:48 PM
vinnys's Avatar
vinnys
Default Re: Battery Light
Originally Posted by vinnys
Take off and clean the terminals and the battery posts. I think that if the ECM doesn't see good voltage through the battery, it will trigger the light. Check the water level in the battery. Should be able to see the acid when you remove the caps. If it's low, fill it with distilled water. Worth a shot. Good luck
Did you do this?????
