Old Aug 6, 2013 | 12:01 PM
TXCF's Avatar
TXCF
Default Re: HELP with noise from behind the dashboard (AC Unit)
Originally Posted by HarleyGuy
We heard noises in our air conditioning fan motor so I took it apart and cleaned out the filter AND the fan blade housing. We have a 2006 Crossfire, Roadster Limited
I was pretty sure it was leaves and I think the air intake design is bad cause it lets a lot of leaves get into the AC filter area and on into the fan housing
To remove these leaves you have to remove the glove compartment
Attachment 29017
Attachment 29018
Attachment 29019
Attachment 29020
Attachment 29021
And then drop the fan FILTER
Attachment 29022
Attachment 29023
When we did this we saw tons of leaves in the filter. The filter drops down after you slide the white plastic holders aside
Attachment 29024
We also had leaves in the fan housing
Attachment 29025
Attachment 29026
Attachment 29027
Whole job took about 2 hours
Great write up and pics. I noticed when i have the AC on and step on the gas i get a whistling noise from the right side of the dash. If i let off it stops. Is this caused by filters clogged/leaves and junk?
