Old Mar 24, 2006 | 08:21 PM
xrtime's Avatar
xrtime
Default Help - Convertible Top Won't Go Down
I was detailing my car this evening for the beautiful weekend here in Florida and had the top half down with the tonneau cover at 90 degrees and thought it was only there for about 5 minutes. The manual says it can stay for 10 minutes and then there will be a beep warning. There was no beep! Anyway, the tonneau cover slowly collapsed and the rear window portion of the top slowly collapsed (which is what is supposed to happen after 10 minutes) and I was able after pushing the top down/up button to get it to lock in at the rear and so I assumed everything was fine. NO! Now it won't go down! I read that you can re-pressurize the system hydraulics by "lowering the tonneau cover manually to its full open position" and pressing the convertible top switch twice. This is confusing to say the least. How do you LOWER a cover to its OPEN position? You would have to RAISE the cover to have it be open or you would LOWER it to be CLOSED. Since it is closed and locked, I have tried pressing the button but do you toggle it to the "open" side twice or to the "close" side or do you press straight down on it twice? I have tried all the above with no success. If you have to unlock the back window part of the top, How do you do this? I can access the underside through the trunk but do not know what to do and there is nothing in the manual. Hopefully, somebody out there can offer some help; the dealership is closed till Monday. xrtime
