onehundred80
Its a drain hose for the central area under the cowl, make sure it is not plugged up as water gets into the car otherwise.
The irony, you know what. I thought it was a drain hose based on the location being in the center, but then I thought it would be odd and ugly to literally just have one in the middle and I was thinking would it be a good idea to have water draining on the tranny like that even though it is seal.
Weird spot for it to be since the tranny is there and everything. Thanks for the quick reply. Now its off to build up my tune list.
Since this car I bought is bone stock, it does have alot of miles 116k, its time for a major tune up. Whoever had it before me had the stealership do most of the stuff, so Im assuming an woman had this car, another reason being the rims have curb rash like no tomorrow. Whoever had it before literally love to eat the side of curbs with the rims, ill have to replace them one day. So my tune up list is as follow.
Plugs and wires
add a oil catch can from needswings
oil change
air filters were change before I bought the car they are clean
crank position sensor (since it threw a code)
secondary air pump since the O.G one fried itself
That should get it back to running a lil bit better.
