fer: I ordered a piece 12" x 60". This is more then enough to cover the molding with some leftover. The vinyl can be cut with "house" scissors. Its ok to cut the pieces a little larger than the area to be covered; this will allow you to "roll" a small amount under the edges. It'sa simple task to remove the backing and apply it as you would tape...removing the backing as you smooth the vinyl while applying it. Instruction are included with the order. All you need is a sharp Exacto knife. If I was set up to send pics via the internet, I would include..I'm working on this... The finished worked is very professional and eye catching. I really like mine...especially the cost!!
