Old Aug 18, 2013 | 03:10 PM
pizzaguy
Default Re: Need Help Felllas
Originally Posted by SrWilliams
I am a little confused. Why would I go thru and completly rewire the woofers in the rear. Already they are playing fine with the way I have them hooked up directly to the amp. Then, I am running the Kappas directly to the amp, without using the pre outs. Why couldn't I simply detach the kicker tweeters from the amp and run some wires from the tweeters (kickers) directly to the preout hartness wires in the Kenwood. Wouldn't that take the tweeters out of the amp equation and only have the amp pushing the door woofers and the rear woofers, which is what I was doing before with no problem
I quess what I am missing Pizza is why would it not be possible to run some wires from the Kisker tweeters to the preout harness block of the Kenwood and keep everything else as is
Well, this is what I am saying. I ASSUMED you had everything already running off the amp, all you need to do is run the wires from the tweeeters to the back of the Kenwood and use the front speaker outputs. Then, use the rear speaker outputs to drive the amp which then drives the door speakers and woofers in behind the seats.
Stay away from the preamp outputs. I just did read up on it, and the amp is expecting to be driven by a SPEAKER OUTPUT, not a preamp output. THe preamp outputs on your head are useless in this car. (Which is no big deal.)
