Thread: OEM Trunk cover
Old Aug 20, 2013 | 07:31 PM
onehundred80
Default Re: OEM Trunk cover
....or you could buy the threaded inserts
Threaded insert - Ask.com Encyclopedia
You need the stand off which the socket head cap screw provides or you'll need to add a spacer over each insert. If you do not have a stand off you will crush the carpet and it would look bad if you removed the cover mounting frame.
