Old Aug 25, 2013 | 01:10 PM
onehundred80
Default Re: Air vent problems
Originally Posted by jimmirehman
i have this problem with any setting, they are old and loose and the slighted imperfection in the road causes them to point upward. I would assume replacing them is the only option but i am open to suggestions... someone else has to have had the same issue.
Why can't you add some kind of interference to the spindles on each end on some or all the louvers ?
There must be some form of friction method now and surely it can be added to.
Take out the vent and look at it. That has to be cheaper if it is possible.
