Old Aug 25, 2013 | 07:41 PM
  #734 (permalink)
arejohn's Avatar
arejohn
Default Re: Chrysler to Replace '05 Convertible Tops Under TSB - YAHOO!!
Ted, what is the new tsb number?
Originally Posted by ted hammonds
apparently you must think that you are hot stuff and can tell people to shut up over a computer well i am not impressed with you at all bud. My info came from a chrysler dealer and i do not work for chrysler, here is the bulletin again and if you can read then maybe you will understand what it says
this bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of chrysler group llc.
this bulletin supersedes service bulletin 23-035-11, dated september
01, 2011, which should be removed from your files. This is a complete
revision and no asterisks have been used to highlight revisions.
subject:
convertible soft top back glass loose and/or detached from fabric (10 yr. / 100,000
mile warranty extension)
overview:
this bulletin involves inspecting the convertible soft top back glass and if necessary
replacing the convertible top cover.
models:
2005 (zh) crossfire roadster
note: This extended warranty bulletin applies to vehicles equipped with
convertible soft top.
symptom/condition:
the customer may experience convertible soft top back glass loose and/or detached from
fabric.
diagnosis:
if the customer describes the symptom, perform the repair procedure.
parts required:
