Old Sep 4, 2013 | 03:00 PM
  #631 (permalink)
awdspyder98's Avatar
awdspyder98
Default
Originally Posted by sk8erjosh09
Correct me if I'm wrong but it's just clutch packs and a different tuned TCU right?
Mmm. Thats interesting. . I would imagine its mostly a tuned tcu with a bigger trans cooler for the autos. Basically to turbo a car all you need are the parts.. install them correctly.. and be able to tune it succefully . The mechanical part of the installation would be pretty straight forward.. you could have some type of custom manifold built to support the turbo or the cheaper way out would be have it mounted in the rear of the car and just plumb the aluminum 2" pipe to the intercooler. Not sure how much room is under the car to run the pipe since I haven't jacked mine up yet. You could use a stock supra side mount intercooler and mount it under the fender well and get airflow through the fog light hole. then plumb the intercooler to the TB.. then its just a matter of installing the mass air flow sensor to monitor airflow. I know Im leaving a lot of the small things out but you get my drift. The real tricky part would be the tuning aspect of it , which I have no idea about. I would assume running 8- 10 pounds of boost through a na block would be okay but Im no expert, just thinking out loud.
