Old Sep 10, 2013 | 09:04 AM
onehundred80
Default Re: FS:Factory NAV unit with GPS antenna
Originally Posted by BradleyG
Hi, Will a navigation unit fit right in and work if the vehicle was not originally equipped with a navigation unit. 'i have a SRT6. Thank you
No, you will have to add at least one wire. I have added this unit to two Crossfires, the first an '04 which was pre-wired for the GPS and thus needed no wires to be added. My '05 SRT6 needed two wires to be added according to the instructions, but I only added one as I could not find the reverse wire to splice the new wire into, it works fine without it.
The OEM GPS is about 9 years out of date with no updates available, I do not care as I wanted the car to have that option anyway, it gets you there, it is a bit antiquated but as long as the road was there in 2003 you are fine. I use a Garmin or a Magellan.
I will attach info on the install and a thread on the installation. I hope this all helps.
Installing the OEM GPS unit (PDF)
GPS radio manual.
How to down load the GPS CD's
