Old Sep 12, 2013 | 07:44 PM
  #117 (permalink)
onehundred80
Default Re: A potential nightmare averted… thank you Crossfire Forum! Crankshaft Position Sen
A factory new RCM for our cars ( if there is such a thing anymore ) will be just like the one that came in your car when it was new.
Over the years and heat/cool cycles under the hood, along with mechanical stress, the wave soldered factory boards
will most likely develop the cold/cracked solder joints.
I am of the mind that a 'repaired' one , done properly, is probably MORE reliable than a factory issue one, since it has extra solder on the critical joints.
And then, I could always be wrong.
I think we can ignore any so called stresses due to vibration and heat etc. The problem lies in the wave soldering, the posts did not get properly pre-heated and or fluxed and therefore were prone to a cold joint or dry joint - period. Solder has changed in Europe, they went to lead free solder, the wave soldering was the problem though, not enough heat, you can sense that when you re-solder them. Anyone who wants to waste their money on a new one I say let them, maybe we can get their old one cheaply.
