Thread: battery drain
Old Sep 16, 2013 | 05:12 PM
pizzaguy
Default Re: battery drain
Originally Posted by chris1_uk
hi guys i did try looking for an old post on subject but couldnt see one
on my 2004 crossfire the battery keeps draining, ive tried putting a brand new battery but after a short while again the battery drains
would be very greatfull if someone might have a few ideas for me to see what is causing the drain
cheers chris
Are you SURE the alternator is charging? A simple voltmeter plugged into the lighter outlet will show you if it is. If it is, (and Im sure it is - but since I'm not there, I thought I better mention that) then:
Take a battery cable off, and put a meter in series with it and see for yourself what is REALLY going on.
The manual says that 35 mA, that is, .035 amp, is normal. If you measure more than that, start pulling fuses until the the current goes down - you will isolate it to a single fuse, usually, in no time. THEN the real work may start.
