Old Sep 17, 2013 | 03:56 PM
onehundred80
Default Re: Lock/Unlock alert sound
Originally Posted by sk8erjosh09
Software is all I can think of. One is pre-coded to beep the other isn't. I know in DAS it's just a setting based off countries. On MBWorld they call it "The Netherlands mod".
That cannot be it, the guy and others, just put the siren in and it beeped, the siren that was in there did not. To my thinking that means the software is already configured to beep.
I can only assume that the OEM siren in the crossfire did not have that capability.
Or, that the pins on the siren were differently configured and thus did not operate the beep. I think software does not come into it other than what I mentioned above.
Or, they saved money and replaced there original intended part with some cheap and obsolescent sirens. (Say it isn't so.)
Years back people were convinced that changing the program would make it beep, all attempts failed. It may be possible that programing changes may switch it off, no one has said the new siren did not beep.
Similarly the DRL feature was thought to be a program mod, it was found that a different part was required. People paid good money only to be told that it could not be done even though they were first assured that it could.
Netherlands mod? Is that when you replace all of the bulbs with tulips? (forgive me, I've used that line before)
