Old Sep 19, 2013 | 04:06 PM
AKING57's Avatar
AKING57
Default Re: top windshield trim
OK repair carried out. Quite easy to remove the trim, top first then side. As some clips were already detached from the trim it was easy to get a long screwdriver under the trim and spring the clips apart to release the trim. I had three clips that had come away from the trim, two on the top and one on the side. I cleaned the clips to remove the sticky residue and then used JB Weld epoxy to stick them back on to the trim. Left for 24 hrs to set and re attached to the car. Now as solid as a rock. I advise anyone with a loose trim to do this easy repair before you loose it. I took some photos during the repair for others to follow.
