SRT6 Gang Member
Cliff notes to accompany the above summary......
As stated earlier we do not need to increase fuel pressure, we need to increase fuel volume and be able to maintain pressure. That is a huge difference. Also, if you only have low to mild increase in boost (2-4 lbs) a walbro pump should be sufficient. The stock fuel filter/regulator has suffecient flow charastics to supply an ample amount of fuel for most if not all engine modifications.
