Old Sep 22, 2013 | 11:56 AM
onehundred80
Default Re: Hard rain; water coming down from under dash
Originally Posted by West Peterson
One of the center drains and the right side drains were completely blocked. Thanks for your help.
If you park near trees this is very common. It is also a good idea to look behind the windshield washer bottle lying under the passenger side fender. I was in there looking at the WW bottle and there was a lot of leaves in there behind the bottle. When these build up and get moist you'll have a small compost heap attacking the steel. I cleaned mine out and applied some u/coating to the area.
It is awkward to get to but leaves and such that go through the drain just sit in there, they just drop into that area with no direct route out.
