Re: Ignition key won't turn
I have the stuck key problem and used the great instructions from the forum. I drilled the locking pin, got the steering lock assembly out, opened the hatch, launched the spring, and got the other pin out. The problem is my key still does not turn and I cannot get the key tumblers out. The lock seems to be what is called the number 1 position and the key can be removed. Any thoughts on what is wrong or is it time to go see the locksmith? Attached are a couple pictures.
Thanks for any help.
