HOW TO replace headlight bulb. Pictured step by step instructions
Oct 4, 2013 | 10:20 PM
115
permalink
onehundred80
Apr 2006
25,432
650
Ontario
Re: HOW TO replace headlight bulb. Pictured step by step instructions
Quote:
Mrmiata
Edit to above.. yes you can get the clip back on.. you don't want to go there.. but you can do it.
Now ask me how I know..
Putting the clip on is quite easy, you put the index finger of one hand on the raised hinge of the unit and hold the spring slightly pinched together in the other hand. Slide the end of the clip under the tip of the index finger and feel the end enter the hinge point. Repeat this with the other end of the clip. You do not even have to look at what you are doing, it is all done by feel.
Tie the clip to a piece of string or something so that if you drop it you can find it easily.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
