Old Oct 9, 2013 | 11:27 PM
pizzaguy
Default Re: Interior Lights Stay On
Make absolutely no sense. If, as you say, you pulled fuse #9 and the lights stayed on,
then check the liftgate lock switch. Perhaps it is causing the BCM to supply the voltage on pin 75 ?
( see schematic )
WHICH fuse 9 did he pull?
THere is a fuse #9 under the hood and another one in the dash fuse box.
