Old Oct 10, 2013 | 10:24 AM
ala_xfire
Default Re: Check engine lights
As sparky said :
PO410 can be caused by the Secondary Air Pump failure due to bad contacts in the RCM
It is not the usual bad solder on the 3 board connectors, it is burnt contacts on the air pump relay.
You can try taking the armature off that relay and cleaning up the contacts with emery paper, or you can replace the relay.
