Re: Roof wont open
I was also having problems with the top going down. First, I installed a rocker switch that is parallel to the divider's micro switch. Since that did not work: I started reading here again on the board. You guy are gereat! Seems that the problem was with the micro switch just above the passenger's head. This swith is not easy to see, as stated. Seems the best and only view is from the out side of the car, on passengers side; the switch is certainly just above the passengers head and as stated, can only be seen with the top unlatched and pulled back the normal six inches or so. I am not certan how to correct the problem; but can say that the top worked fine once I manually moved the switch a tad.
thanks again from New Ellenton, S.C.
