Old Oct 10, 2013 | 03:37 PM
onehundred80
Default Re: Check engine lights
Originally Posted by cookiemonster131
air pump relay contacts were clean but i polished them with emory and went ahead and resoldered the RCM 3 points that people repair.
I will test drive it as able but it is a pani right now with not being able to hardly get gas in it
If they were clean then they should not have been touched as they are quite polished, I do not know what grade of emery you used but just the name emery means it was coarser then a polishing paper. If it is quite rough the contact may spark from different points and burn the faces.
Points are polished and normally at least one is domed to focus the spark.
That's my opinion anyway.
