Re: Headlight bulb replacement
A couple of questions-What do you mean by "bright bulbs/hid bulbs" and was it easy to change the bulbs in either location? I have changed the bulbs by myself and had alot of trouble getting the clips back on,and I have had a quick lube place replace the bulb and it took them less than 3 minutes.Either way,I will not attempt this task again as the quick lube way is the best way to go!
