Re: New dyno on tuesday
Here's the graph. A few notes. No correction factor, no AFR's, hot off the street and other disclaimers when I need them. They tried 2 sniffers and neither read less than 15 AFR. My wide band is giving me good AFR's so onward we went. My last dyno was 339 hp. It wasn't my highest dyno of all time but the most recent. The attached graph is the second pull. Both made the same power. The torque was lower on the pull on the graph. Heat perhaps? Both pulls hit the rev limiter. I took a video and hope to see the precise rpm it engages. 6345 rpm is for sure though. Temperature was 92º at the time of the dyno. My first ever dyno at Predator Performance was around 260 to 270 hp. 370 hp, for me, celebration time!
I'm open to critique, observations, haters, what ever you feel. Naturally easy down the road is the plan until I get some good data logs, because you can never be too careful. Oh, the gas was a 50/50 mix of 93 with 100 Sunoco.
Les
I'm looking at the graph now, WC is with correction?
Reason: Correction factor
