velociabstract
I have bad news for header dreamers. On our supercharged, no overlap cammed engines, headers just don't do much. Most of the gains come from removing the cats. A N/A Crossfire will see more gains than a supercharged one. Ouch! I've been told my results are unusual but it is what it is.
Les
Les, what are the measurements on yours? Primary diameter, primary length and collector diameter? From what I understand the primary diameter with 75% volumetric efficiency should be smaller than our port size which is 1.5"... It sounds crazy but anything much bigger than 1.5" is loss.
Mrmiata
They really don't do bad.. Just a shot here to show how easily they would mount up. Just be a matter of finding some with the right curves really..
Solid would probably do better too, I like the hoseclamps but maybe my welder can bracket the shield, fixed, just above the primaries with little contact... That way the clamp isn't touching the pipes as much, transferring all of the heat to the shield.
