Old Oct 23, 2013 | 08:45 AM
  #62 (permalink)
onehundred80
Default Re: Alarm going off on its own! Interior light flickers / unlocking randomly if drivi
Originally Posted by adelaideXF
Today I locked the car and 10 minutes later the alarm went off and it was extremely loud and key fob could not silence it. It completed it cycle and temporarily silenced itself. The siren was continuous but I could hear strange sounds coming from the siren as if the alarm battery is running out (electricity sound effect ). At the moment I have fuse #9 removed and key in ignition to keep car unlocked and alarm disarmed. I want to keep the alarm from going off. So far fuse#9 and unlocked car have kept it silenced but I am not sure if it is going to keep it off for a week. I know disconnecting the battery will not help.
Right now I am requesting some help as to whether I should remove the Alarm Siren all together or Central Locking Pump Module? Which is an easier job and guarantees no alarm siren? Or fuse 9 removed and car unlocked will keep it off? I have ordered replacement parts but they will take 2 weeks. I need to drive for work but need to get rid of the siren. Thank you in advance. I will look for the module in the trunk tomorrow.
As stated above the siren is the problem, and that is the part that should be changed. Unless you have had a problem with the security/pump module in the trunk I would not waste my money on it.
See the thread where 'Cricket on Crack' is mentioned.
Here is a thread and it is like your problem, it is a bit confusing but the OP is finally asked to say what the problem was and it was the siren itself. The OP originally said the problem was fixed and said the thread was closed, he was finally coaxed into saying what the problem was. After all the time people had spent on trying to fix the problem he was just not going to ay what caused the problem.
