Sik Srt-6
Wow! your getting more use out of this headunit then I ever will.
Keep us updated on your progress.
So far my unit has been pretty good. Ive had a few freezes with the gps portion of it. Primo will freeze if I try and do too many things at once. But its still pretty fast. It only really happens if I switch between gps and ipod for example. But only occasionally happens.
Now, one thing I would love to improve upon for the factory GUI software would be to add some type of graphic equalizer, and fix some of the user interface parameters. First thing being, disabling the touch interaction when the volume display is showing for a few seconds. Prime example, if you adjust the volume with the ****, it will show a bar with your volume range 0-50ish.. if you accidentally touch the screen in the area of the visual bar, the volume will JUMP!.. This is super dangerous since I have a 6ch 600w JL amp running my mids and highs.
If that can be modded, I would be tickled pink!
Just did a simple change, with the file explorer in ceFFM I was able to get access to the internal memory of the head unit and the TPMS software that in the M1 is hidden in there! So I changed the name of the file to Tetris.exe and then deleted the game. So now in the GUI when I click on the Square game the TPMS app comes online.
I'm going to try and do the same thing with an OBDII app since that's all I want, I don't need the 40 apps that come with CeFFM or MioPocket.
