ala_xfire
No, but for $30 less, you can get a set of Magnecore wires AND a new set of plugs from NeedsWings :
NeedsWings Ignition Kit Crossfire
( but then I see you already know this, as you list both in your sig )
Yes, I do have this kit installed. I'm not all that keen on the plug ends of the Magnacor wires -during install if you were not spot on and pushed to click onto the plug the wire would push back into the boot forcing you to go into the boot with long nose pliers to pull it back down to grab the top of the plug.
This set however comes with the OEM style plug ends, but you are right there is a big difference in price. The 8.5mm set that they sell is $50.00 cheaper.
